Radio sport headset in mic profiles
I used my radio sport 1oth anniversary headset with my 6600 M. Can't remember what mic profile that works with the 8400M. M 207, 208, 350 20?
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    I suggest just create your own. Depending on what you do affects shape of the audio curve. For example, if primarily DX or chasing parks audio curve would cut below 400 and above 3000 or so to focus in the voice range for intelligibility. Always cut before boost.
  • KB4OIF
    KB4OIF Member ✭✭
    Hi John. I run mine at 300-2850. what I was looking for is the right profile in the 8400M list of already in there profiles on the flex. I found that 20 works, but I think I used another one when I used this headset before???
    John, it is better to build your own. Find any profile that gets it working and then start to tailor it to your voice (everyone is different). You can use the FDX feature of the radio to listen to yourself or even record a 2nd receiver and then play it back.
  • KB4OIF
    KB4OIF Member ✭✭
    thanks Mike I found one and will work on it today.
