FRStacks3 and PGXL
Stacks3 is not reporting any info from my PGXL. With the amp powered on the fields show up in Stacks3 but there is no data populating the fields.
I've restarted the PC and the PGXL.
Any ideas?
Well…oddly this AM I see data in the amplifier fields.
The amp was in standby overnight, I selected operate and it looks as I expect now.
Gremlins?
It can happen if there are too many TCP connections to the PGXL. Power cycling the PGXL usually resolves it.
-1 -
Mike…Can you explain the scenario that would cause that condition?
I had previously, yesterday, restarted the amp and the problem persisted.
No, it was something that 4O3A mentioned to me some time ago. There is a limited number of available TCP sockets, but I am not even sure it is related. You may wish to reach out to 4O3A as they own the software solution.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
