FRStacks3 and PGXL
Geoff AB6BT
Geoff AB6BT Member ✭✭✭
edited November 2025 in Third-Party Software
Stacks3 is not reporting any info from my PGXL. With the amp powered on the fields show up in Stacks3 but there is no data populating the fields.
I've restarted the PC and the PGXL.
Any ideas?
  • Geoff AB6BT
    Well…oddly this AM I see data in the amplifier fields.
    The amp was in standby overnight, I selected operate and it looks as I expect now.
    Gremlins?
    It can happen if there are too many TCP connections to the PGXL. Power cycling the PGXL usually resolves it.
  • Geoff AB6BT
    Mike…Can you explain the scenario that would cause that condition?
    I had previously, yesterday, restarted the amp and the problem persisted.
    No, it was something that 4O3A mentioned to me some time ago. There is a limited number of available TCP sockets, but I am not even sure it is related. You may wish to reach out to 4O3A as they own the software solution.
  • Geoff AB6BT
