SmartSDR for Windows v4.01
Hi,
On SmartSDR for Windows v.401, when I choose 20m on the Band option, the radio does not switch to 20m. Stays on the same band it was previously. In this example, I was on 30m band. Also the slice and the data associated disapears.
Please help.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThe region codes did change in v4. However, you should still be fine with normal operation.
You'll need to open a support ticket for the other issues.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi
Try reseting the radio and see if that resolves it. https://helpdesk.flexradio.com/hc/en-us/articles/360020078612-How-to-Completely-Reset-a-FLEX-8000-6000
Is it the same procedure for a FLEX-6400M? I have both Smartlink Account configured in the 6400M and SmartSDR for Windows.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsPaulo, if you are asking about resetting, all models are covered in that helpdesk article. Sorry if that is not what you are asking.
Ok, I did the Hard Reset. Why is my region NOR? Also, I still need to wait more than 3 minutes for software versions to appear.
Thanks Mike. The only issue I have now is waiting time of more than 3 minutes. SmartSDR for Windows is now behaving ok on 20m.
vy 73
Paulo
- 681 The Flea Market
- 219 DAX
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
