Remove old versions from Select a Version screen?.
EA7Z
Hi:
It is possible to remove old versions of firmwares of this screen? I think that so many versions slow down the radio's startup.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIf you only have 1 radio, then you can turn on the auto connect to last radio and you will not see the versions.
No, it does not slow down the radio's startup at all. Well, I guess if you it has to wait for you to pick a version, that is slowing it down.
The autoconnect will help you out.
Ok, thanks a lot.
- 197 SmartSDR+
- 322 Shack Infrastructure
- 227 Networking
