Remove old versions from Select a Version screen?.
EA7Z
EA7Z Member ✭✭
edited November 2025 in FLEX-6000 Signature Series
Hi:
It is possible to remove old versions of firmwares of this screen? I think that so many versions slow down the radio's startup.
    If you only have 1 radio, then you can turn on the auto connect to last radio and you will not see the versions.
    No, it does not slow down the radio's startup at all. Well, I guess if you it has to wait for you to pick a version, that is slowing it down.
    The autoconnect will help you out.
  • EA7Z
    EA7Z Member ✭✭
    Ok, thanks a lot.
