Remove old versions from Select a Version screen?.
EA7Z
Hi:
It is possible to remove old versions of firmwares of this screen? I think that so many versions slow down the radio's startup.
If you only have 1 radio, then you can turn on the auto connect to last radio and you will not see the versions.
No, it does not slow down the radio's startup at all. Well, I guess if you it has to wait for you to pick a version, that is slowing it down.
The autoconnect will help you out.
Ok, thanks a lot.
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
