DVK - Mute RX audio during recording and preview
Geds42
Geds42 Member ✭✭
My initial recordings using DVK did not sound very good at all.  Once I muted the RX audio, the recordings and playback were excellent.
Suggestion:
Why not automatically mute the RX audio when the Record and Preview options are selected on the DVK menu?
5 votes
Active · Last Updated
    If you are on the Early Access program you should have received an email on how to provide feedback. Make sure you use it.
  • Geds42
    Geds42 Member ✭✭
    Yes, I will. That email came after I posted this. Thanks!
  • James Kennedy-WU5E
    James Kennedy-WU5E Member ✭✭✭
    this should be the first to release to SmartSDR+ next week
  • WA7NPX
    WA7NPX Member
    Hi Mike,
    I signed up for Early Access last night and received numerous emails and none have info about how to provide feedback. FYI
    (Probably already on your list but I just wanted to suggest a change to the UI allowing editing of the Fkeys to show content such as the CW keyer shows. I.e. such as adding a CQ label or Exchange etc.
    Tom WA7NPX
  • Russ Ravella
    Russ Ravella Member ✭✭✭
    Never got a "feedback" email either.
    73 Russ KR6W
