SPLIT operations - bandwidth receiver B very narrow
If SPLIT is activated, the bandwidth of receiver B is very narrow, to solve the problem I have to change the bandwidth
I’m using 8400 firmware 4.0.1
Has anyone encountered this strange behavior?
Ciao Nicola
IZ1ANL - N1ANL
  • iz7anl
    iz7anl Member ✭✭
    After some testing, I found that the problem also occurs when the second receiver (slice B) is acticvated. It can be solved by deactivating NR from slice A or changing the BW on slice B.
    Ciao Nicola
    IZ1ANL - N1ANL
    Nicola
    • band?
    • Mode
    • filter settings before you go split
    It helps us to recreate the issue.
  • iz7anl
    iz7anl Member ✭✭
    Hi Mike,
    • band: 10 to 20 m, I haven’t tried on low bands
    • Mode: USB
    • BW: normaly I am using 2.4 or 2.7
    Ciao Nicola
    I am not able to recreate this on 4.0.2 (99% of 4.0.1). Can you try a radio reset and see if the problem still exists?
  • iz7anl
    iz7anl Member ✭✭
    Hi Mike, in attach a test card that I sent to Eric Wachsmann, KE5DTO
