SPLIT operations - bandwidth receiver B very narrow
iz7anl
If SPLIT is activated, the bandwidth of receiver B is very narrow, to solve the problem I have to change the bandwidth
I’m using 8400 firmware 4.0.1
Has anyone encountered this strange behavior?
Ciao Nicola
IZ1ANL - N1ANL
Ciao Nicola
IZ1ANL - N1ANL
After some testing, I found that the problem also occurs when the second receiver (slice B) is acticvated. It can be solved by deactivating NR from slice A or changing the BW on slice B.
Ciao Nicola
IZ1ANL - N1ANL
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsNicola
- band?
- Mode
- filter settings before you go split
It helps us to recreate the issue.
Hi Mike,
- band: 10 to 20 m, I haven’t tried on low bands
- Mode: USB
- BW: normaly I am using 2.4 or 2.7
Ciao Nicola
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI am not able to recreate this on 4.0.2 (99% of 4.0.1). Can you try a radio reset and see if the problem still exists?
Hi Mike, in attach a test card that I sent to Eric Wachsmann, KE5DTO
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsSince Eric is testing it, I will not duplicate his effort. Let us know how you make out.
HI Mike,
I guess the problem might be related to the NR, I’m using a basic NR
- 197 SmartSDR+
- 322 Shack Infrastructure
- 227 Networking
