How about adding DSP slider controls in SmartSDR 4?
g7soz
g7soz Member, Unconfirmed ✭✭
Would be a great idea! ;-)
9 votes
Active · Last Updated
  • Dan Trainor
    Dan Trainor Member ✭✭✭
    Brillant Idea! :)
    There isn't much to go on with this that will help engineering. What is it you are trying to achieve?
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    Look at it this way Mike, What is it in the new algorithms that made the programmers eliminate the slider adjustments? If its because they are not necessary then that should have at least been mentioned at some point.
  • Trucker
    Trucker Member ✭✭✭✭
    Some of the new DSP functions are more complex than what we have been using. Making adjustments to different values that the new algorithms use will probably require more display area to accommodate the extra settings. I would think that adding something like a Right Click on a DSP button could present a pop-up menu with sliders or whatever is needed to provide a value or set of values to the algorithms that can then be saved and exit out of the menu. There could even be a reset to default button on the same menu if the new settings don't do what the user needs it to do. This would eliminate having a lot of sliders and other controls visible all the time. I like the idea of having a clean looking interface. But, taking away the user's ability to fine tune different functions to suit their local environment doesn't make sense to me. Put the extra controls on pop-up menu's and make them accessible by Right clicking on the relevant button on the screen.
  • g7soz
    Hi Mike,
    In case you’ve not yet seen it, there’s a discussion about the loss of functionality here https://community.flexradio.com/discussion/8032476/smartsdr-4-0-1-basic-sliders-missing#latest
