Flex 6500: Frequency is drifting downwards....
HB9DDS
My Flex 6500 has the following problem:
When switched on and operated via SmartSDR, the frequency constantly drifts downwards.
Does anyone know about this issue with the Flex 6500:
The frequency adjusts itself because the device registers phantom activations at the up/down button connections on the microphone plug. I solved this by soldering two wire bridges from the up/down pins to ground. This keeps the levels at the up/down pins permanently at a defined level, and the frequency remains stable.
Daniel
HB9DDS
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsplease open a support ticket. this is abnormal.
Also, make sure you have updated to the latest software.
- 681 The Flea Market
- 219 DAX
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
