Flex 6500: Frequency is drifting downwards....
My Flex 6500 has the following problem:
When switched on and operated via SmartSDR, the frequency constantly drifts downwards.
Does anyone know about this issue with the Flex 6500:
The frequency adjusts itself because the device registers phantom activations at the up/down button connections on the microphone plug. I solved this by soldering two wire bridges from the up/down pins to ground. This keeps the levels at the up/down pins permanently at a defined level, and the frequency remains stable.
Daniel
HB9DDS
    please open a support ticket. this is abnormal.
    Also, make sure you have updated to the latest software.
