SmartSDR 3.10.15 still does crashes with HWALC
Hello,
I reported several versions ago that SmartSDR for Windows crashes immediately when using HWALC.
Fixing this very dangerous bug doesn't seem to be that important to Flexradio.
73, Hardy
    I could not recreate this on 3.10.15. Please open a support ticket or respond to the one you currently have open.
    thanks
  • Hardy
    Hardy Member ✭✭
    I described the error in detail and reported it to support.
    There's nothing more I can do other than wait...
    @Mike:
    You need to enable hardware ALC, and then an ALC voltage must actually be present.The error is the same on four PCs – Windows 10 and Windows 11 – the Maestro (A) is not affected!
    Got it. Make sure that is clear in your support ticket. I know we do not have an amplifier that has a hardware ALC line, but we could easily enough test it with a voltage divider and a 9v battery.
  • I can confirm the issue is present, I have exactly same issue on latest SmartSDR.
    Marek SQ2GXO
  • Hardy
    Hardy Member ✭✭
    The bug was not fixed in version 4.1.3 either. Security is clearly not a priority.
