Should I be able to tune in RTTY mode?
In all modes except RTTY, going into Tune produces a carrier as expected.
However, as I found out in CQ WW RTTY Test this past weekend, in RTTY mode it is not possible to Tune.
There is no output from the radio.
Some versions ago, Tune worked fine in RTTY. Then there was a bug introduced where, although Tune worked, the carrier was +2kHz from the dial frequency. In 3.9.19 there is no Tune at all. Should it be like this?
I did do a radio reset but to no avail.
Erik.
Do you have DAX on?
Yes John, DAX is on. The issue is not DAX related but mode related. With same settings and working in SSB, CW, DIGU etc there is no Tune in RTTY.
Erik.
I get the same on my 6600 Erik.
Rich
Rich - thank you for confirming.
Is it a bug or is Tune deliberately suppressed in RTTY? I cannot imagine why it would be and it did not used to be this way.
Erik
When I click on tune here in rtty mode, I get power out to whatever I set tune power to on my 6600 and 6400 using Mac or Windoze SSDR. I'm on the latest version 3.10.10.
Tune does work in RTTY mode. If you are not able to, please open a support ticket so we can track it to a root cause.
thanks
I am on 3.9.19 due to the broken IQ stream in 3.10.10 and that could be the reason for no tune if it was fixed recently. So I'll wait for the next version, update and see if it works then.
Thanks for the feedback.
Erik.
I participate in a lot of RTTY contests and I don't recall ever having any problems with tune in any version.
But some are, as shown above. So something either is or has been amiss somewhere.
It was given SMART-11364 when I reported it months ago.
Erik,
I also have the no power with TUNE in RTTY mode, 8600 running 3.9.19. Which is a bit annoying as have to stop SDC in order to change mode to something else, tune antenna and then restart SDC contest.
Hope this is will be fixed in an upcoming release.
73, Jonathan G4IVV
It is very annoying. It plagued me in CQ WW and now in JARTS. Reported months ago.
- 369 Community Topics
- 628 The Flea Market
- 85 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 244 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 916 Genius Products
- 333 Tuner Genius XL
- 451 Remote Operation (SmartLink)
- 780 Peripherals & Station Integration
- 996 Third-Party Software
