MORCONI, the ultimate CW interface.
If you’d like extra space for memory buttons—or simply prefer a wider enclosure—you can download the V4 STL files from the web site Download page:
Will this produce sidetone through the computer's speakers?
Not a separate PC if your using with SmartSDR, it has it own Audio sidetone on a pinout on the Teensy Micro-Computer, you can use a pair of Computer Speakers to listen to the sidetone Audio or like some have done use a small amp board and Speaker installed in the case, It may NOT fit in this case however depending on what Amp and speaker you end up using so is best to use separate computer Speakers for sidetone audio.
Alternatively, you can route the MorCoNI output into the Line-In or Mic input of your sound card and use the Windows audio mixer—or, even better, a third-party mixer like VB-Audio Banana or Potato.
This allows you to seamlessly mix the sidetone, SmartSDR, and anything else you want through your computer’s audio output device.
That’s exactly how I designed it, and it’s how I use it every day
A beautiful custom made Morconi in blue with LED and memory buttons.
Enjoy it, Jaime!0 -
Excellent toy for Flex-CW-Remote operators.
It took some time to test MORCONI, as at 4U1GSC we had problems with internet for almost a year. Today I have finally connected MORCONI to 4U1GSC FlexRadio 6600 and was nicely surprised how well it works. This was one of the features missing when using SmartSDR only. With MORCONI, sending remote CW without a glitch seems to be reality.
Great work Max, I now just need to open port 4992 for each remote radio and SmartSDR perfect CW is now possible.
73 Ivo I7/9A3A, E73A, 4U1GSC op.
Watch Eric, NP3A running CWT remote with his Flex and the MorCoNI!
NP3A CWT Sept. 10, 2025 - YouTube0
- 345 Community Topics
- 612 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 407 SmartSDR for Mac
- 266 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 202 FLEX-8000 Signature Series
- 919 Maestro
- 891 Genius Products
- 453 Power Genius XL Amplifier
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 751 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 971 Third-Party Software
