3.10.10 issue tune button will start the tune process
I notice this on two different bands, with TUN integration active. My 80m needs tuning about 3.800 so I dial over too 3.975 GA SSB net hit the Tune button nothing happened. I restarted SmartSDR no change. I only tune my antenna with Tuner App
using trick to uncheck the PGXL inside the tuner app didn't help
Jim
WU5E
At what Frequency does it start to work? It could be (and I am guessing) that a TUNE defaults to USB internally and your LPF for SSB is a very large number that takes you out of band. Without a screen shot I am sort of guessing the issue.
i MUST have explained it wrong, normally I don't use a tuner below 3.800 above that I need to use a tuner. so on GA SSB Net I dialed up 3.975 and hit the tune button TUN Operate is GREEN and nothing happened. I started the Tuner Genius XL app select band A and hit TUNE and it tuned the freq.
I have rebooted the radio same thing
I have rebooted the TGXL (SO2R) Nothing
everything looks like tuner integration is working but it's not
I have to use the TGXL app to tune my wire.
I have attached a screenshot
I rebooted the radio for third time and now the tuner on SMARTSDR works
Did you remove DC power from the radio for at least a minute after 3.10 upgrade?
73 Dave wo2x
Hey Dave,
I've been removing power for 30 seconds for a long time per instructions at the time. Has it been determined that a full minute is required now ? Or perhaps it changed after an upgrade back there somewhere ?
Thanks, 73 Russ KR6W
No but I always got in habit of a minute from the M series power up. The main thing is if you remove DC cable vs turning off the supply then you don’t have to worry about the voltage slowly dropping due to capacitors in the supply.
73 Dave wo2x
- 651 The Flea Market
- 50 Aurora
- 965 Maestro
- 938 Genius Products
