Looking for basic help with the SDR-1000
Hello everyone,
I came across an SDR-1000, like a **** giving birth.
I have no idea about this version, but I want to get it up and running.
What I know:
- It is the QRP version.
- I still have a 2-meter transverter board.
That's all. Maybe I can get it working with the help of SDR-1000 owners.
Problem:
- I don't have the actual PIN assignment for the parallel port, despite the diagram, which doesn't provide much information.
- When I connect the SDR-1000 to 12V, nothing happens. Should something click or light up?
- Are any boards missing (apart from the 100W PA)?
- How do I proceed now?
I also don't kno which Version this is
I think I first need to connect to the PC, install the software (which one?) and then see what happens.
But first, I need the parallel PIN assignment or a ready-made USB to parallel adapter.
Daniel
HB9DDS
If all is running, this is the secons step.
Daniel,
Bring an SDR1000 to life will be a challenging due to the number of dirivers no longer available or useable on current OS . You can use the on board soundcards, but was a much better performer with external sound cards, running XP or maybe Win7 .
- As I remember, the parallel port was a 25 pin straight through.
- On power up, there is nothing to light up, until you have the parallel port connected to a true printer port. I never worked with a USB to lpt port, so you need a motherboard with a LPT port or a true LPT card.
- I think all the sound cards were ISA cards, unless you use the Ediral Firewire sound adapter (then you will need a FireWire port, run with old drivers.
- I presume that there never was a 100W board with that stack, there were a couple of jumpers on the stack if there were a PA..
Without a better sound card, the radio is pretty limited with lots of spurs and limited to 48K at best.
If you have an older PC , with XP and ISA and LPT port, there might be some luck.. They did sound great on AM..
And as I remember you can only run older versions of PowerSDR , version 7.53 pops up in my mind, last version to support the LPT port.
Flex1500 is a better choice , connects via USB, and can run the later versions of PowerSDR by Darrin , KE9NS -
Hope this helps, it can be done, but with an older PC should you still have one ..
Dudley
WA5QPZ
@ Dudley
My first step would be to connect the SDR-1000 to the PC.
According to the manual, there should be a parallel port to USB adapter.
However, to my knowledge, a USB cable has 4 wires.
Now I'm wondering how to connect to the parallel port. Do I need another converter in between? If not, which parallel port pins are important?
That's my problem. The manual does not describe this.
There was a 100W module, according to the manual.
Daniel
HB9DDS
Daniel,
A regular USB to Parallel will not work, there was a special one built by a user that has long since gone SK , was the only adapter that did work, but it long since gone since around 2008. Use a LPT port , (some motherboards have LPT ports, but no header, you can buy the headers on Amazon, but look at your BIOS of the motherboard….
Hello Dudley
I thought so.
So, I can inherit a laptop with a serial port. Let's see what's still working on it.
But my question is:
Where does the video signal come from so that something appears in PowerSDR? Via this serial port?Daniel
HB9DDS
And …
How and where can I get a Powersdr Software, which ist working with the SDR-1000?
Daniel
HB9DDS
So the laptop (IBM Thinkpad 2626 390X) with Windows XP and PowerSDR 1.18.6 is running. That was an adventure... and it takes time (slowly).
Now the problem with the sound card.
Can I only use the sound cards that are listed in Powersdr under Audio? That would be awful.
Does anyone have any tips on how I can proceed? I just want to see if the SDR-1000 works.
The IBM Thinkpad 2626 390X also has a built-in sound card...
Daniel
HB9DDS
Key Question is:
—» Can I only use the sound cards that are listed in Powersdr under Audio?
If that's the case, which USB sound card works?
Daniel
HB9DDS
I now have a different laptop in use. PowerSDR can now be installed and opened (Start).
But... MOX is immediately active... There is no power either...
I think I have a problem with the SDR-1000.
PS: I'm surprised that no more tips are coming in. Too bad.
Daniel
HB9DDS
Hi Daniel… sorry we're not able to provide more help but as you have probably surmised, very frew of us are using the 1000 any more. I think most have been relegated to the 'treasure trove' shelf.
I realize that, but the knowledge shouldn't just be sitting in /on the rack…..
Maybe someone has a working SDR-1000 (+ PA) in their rack and can offer it...
Daniel
HB9DDS
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
