Is anybody using SmartSDR for Mac for serious contesting?
Did anyone try to use SmartSDR for MAC for serious contesting? To benefit from minimal lag.
An easiest way would be to use CAT and DX with N1MM+ on a separate PC or under Parallels. But then, perhaps a lag would appear in voice memories.
Can N1MM under Parallels use DAX under MAC?
Is SmartSDR for MAC stable for contesting? The last version for Windows 3.2.39 seem to be finally stable.
Ignacy NO9E
I ran CQWW SSB remotely.
I setup the MAC with a footswitch and used a RadioSport headset for the audio (user part) and a FlexControl knob. This was with SmartSDR for MAC OS.
I then had N1MM running on another computer with SmartSDR CAT and DAX connected to the same radio for logging. Since I was remote, this PC was local to the radio and I used another computer and Anydesk to connect to it so that I did not have to move DAX Audio over the internet.
It worked very well and I would do it again as it was very simple to setup and very reliable. The top screen is the AnyDesk remote to the PC local to the radio. This is a great tool as I can use a PC or a MAC to connect to it. There is another keyboard below the bottom of the picture that I use for N1MM entry on the AnyDesk connection.
My remote station only has about 2mb/sec reliable upload and I no issue even running SO2R at times. Essentially I replaced the Maestro with the MacBook Pro.
This is a big advantage that the Flex infrastructure design in that you don't have to have everything on the same computer like you do with other OEM radios. You can spread out the data. And, you could easily expand this for N1MM partner mode using MultiFlex and even do it remotely if you wanted to.
Mike va3mw
Ignacy,
I have not used SmartSDR Mac for serious contesting... yet...
Typically when I contest I do CW so I don't worry too much about the DAX for voice memories. I use an external WinKeyer USB to key the radio and run N1MM on either a Windows VM (less stable) or a Windows laptop.
I've only done that for short CWT contests and it works. However I did find that having to have the Mac and Windows was a PITA.
So it is a bit of a catch22. I think in general the mac is very stable and Marcus has done great on SmartSDR Mac, but N1MM will not run on the mac directly. I did try to install it in CrossOver but it refused to work.
So as a developer I have started my own Mac N1MM clone specifically for the the purpose of using native software with the Mac. But this project is slow and is a long time before it will be worth anything.
So I hate to say it, a Windows laptop, N1MM and standard SmartSDR seem to be the way to go until such a time as we can get true N1MM functionality on the Mac.
I know some people use Skookum and others but I've not found any of them to be really SmartSDR mac friendly.
And now that Apple has gone M1 it is difficult to even run Windows in Parallels and VMWare. I have intel Macs so I don't have an issue but I'ver heard of lots of problems under the M1 for running Windows. They'll sort them but it may take time.
Does AnyDesk have any special advantage over other programs like the Teamviewer? Which version of AnyDesk do you run? Do you do SO2R?
SmartSDR for Mac has voice memories. Are these useful in contesting at all?
Ignacy NO9E
Hi everyone, I am using ssdr mac on m1 mac mini and skookumlogger which s not bad, even if has no data files for contests, and it is somehow cumbersome doing msgs config, but maybe I still have to manage it. Also it is viable only with local rig, not remote, because winkeyer must be connected on the back of the rig, thus locally. Since I use also ssdr win on Asus laptop, I could experiment also DxLog for contesting, widely seen as far superior, even with n1mm respect, thus I tried to use ssdr mac and dxlog in a win11 parallel windows, managing interfaces matters similar to ones with skookumlogger, thus radio connections r1 and r2 via tcp and winkeyer thru com3 (just unplug winkeyer usb and replug giving it to windows when requested). Everything works, with the best ssdr mac (better than ssdr win) and best contest logger available, at least with local rig. I think I'll be able also with remote rig, but I am still working on it.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 832 Peripherals & Station Integration
- 145 Amateur Radio Interests
