PGXL on 15 Meters Sounds like a Bongo Drum!!!
When I operate my Flex 8400M on 15 meters and sending CW the Amplifier Sounds like a Bongo Drum. On every other band it is just fine. This seems to be a 15 meter issue. Has anyone else experienced this and if so what may be causing this?
Mark Griffin, KB3Z
Here is another thing, when I reduce the TX Delay to 0 I get the bongo drum sound at the beginning and then it stops. I was sending dah dit dit dit dah. And then when I start again I get the bongo drum sound again.
Here is something else that is unique. When I set the TX Delay to 0 and just send Dit's it doesn't make the sound, and yet when I send a Dah, it does every time. Also when I set the TX Delay back to 40 it sends the Bongo Drum on both Dits and Dahs.
I also noticed when I was just sending the Dit's at TX Delay at 0 it was not keying the PGXL. But it did with the Dahs.
And this does not occur on 15 meter SSB. I even changed CW Keys and that didn't fix the problem.
Make sure you follow the recommended settings:
https://helpdesk.flexradio.com/hc/en-us/articles/20826281594011-Configuring-the-Dream-Station-FLEX-8000-6000-with-the-PGXL-TGXL-AG-for-Proper-Operationhttps://helpdesk.flexradio.com/hc/en-us/articles/20826281594011-Configuring-the-Dream-Station-FLEX-8000-6000-with-the-PGXL-TGXL-AG-for-Proper-Operation
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 783 Peripherals & Station Integration
- 997 Third-Party Software
