Duplicate Flex 6300 ACC for CTR2-Mini+ and VL-1000?
I recently acquired a CTR2-Mini+. I also use a Yaesu Quadra VL-1000 amplifier, which connects to the Flex ACC port for band detection. Is it possible to duplicate the Flex ACC port to use both of these items simultaneously?
Steve, W6SDM
I think the CTR2-Mini connects to the computer, not the actual radio.
The Amp, I think, uses the USB/RS232 port on the back of the radio.
Thanks, Mike, you're right. I got the CTR2 mini used with a plethora of cables, one of which has a DB9 connector. I assumed that was for the ACC port, but it isn't. I found the manual online and downloaded it. Unheard of, right? Now I have to put down my Tom Clancy novel and read it. :)
Steve, W6SDM
After some research, I found that the CTR2-Mini+ can use the ACC and PTT ports on the Flex. However, you can do the same thing over the network. I finally got my Mini hooked up to the Flex and WiFi.
Steve, I have one of these and it has an USB-C mini port that connects USB C connector on the Client. The USB A connector on the back of the radio is only for RS232 support.
This is what Lynn sent me. According to this, I would use pins 8 and 14 on the Flex ACC port.
I did get the CTR2-Mini+ working over WiFi, and I'm able to key the rig. Now I get to explore and see what all this can do. It's kinda like my FlexControl on steroids.
- 375 Community Topics
- 105 SmartSDR+
- 425 SmartSDR for Mac
