Trying to a open a second JTDX using Slicemaster 6000 but does not work for me
I followed the instructions on how to set up a second jtdx using DAX2 but I can not open the second one......it suppose to popup clicking on DIGU but it doesn't, what am I missing?
I received my 8400 this weekend and it is already up and running on FT8 using JTDX but I would like to have a second one to monitor 6m activity, any help would be appreciated.
  • kk4cdk
    kk4cdk Member ✭✭
    Something else, on SliceMaster I suppose to create a Launch setting with name DAX1 and DAX2 but it always change it to Slice-A and Omnirig...... I do not understand that
    One the 2nd slice:
    • Make sure you have a DAX RX channel assigned to the slice (DAX 2 is a good one assuming you are using DAX 1 for Slice A)
    • Make sure you have the DAX Slice active
    Here are some images in no particular order, but they should help. This is my 2M setup for today (one FT8 and the other MSK144).
    This is for JTDX and WSJT but the setup is the same. You want to check this after the 2nd decoder opens.
  • kk4cdk
    kk4cdk Member ✭✭
    Thank you Mike for the comments, I saw your video for these settings and followed it, the only thing that didn't work is that Slicemaster keeps changing the launch name from DAX1 to Slice-A and from DAX2 to Omnirig......it shouldn't be and perhaps it is the problem. Do I need to make any changes on JTDX? do I have to duplicate the files, or something else.
