Trying to a open a second JTDX using Slicemaster 6000 but does not work for me
I received my 8400 this weekend and it is already up and running on FT8 using JTDX but I would like to have a second one to monitor 6m activity, any help would be appreciated.
Something else, on SliceMaster I suppose to create a Launch setting with name DAX1 and DAX2 but it always change it to Slice-A and Omnirig...... I do not understand that0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsOne the 2nd slice:
- Make sure you have a DAX RX channel assigned to the slice (DAX 2 is a good one assuming you are using DAX 1 for Slice A)
- Make sure you have the DAX Slice active
Here are some images in no particular order, but they should help. This is my 2M setup for today (one FT8 and the other MSK144).
This is for JTDX and WSJT but the setup is the same. You want to check this after the 2nd decoder opens.
Thank you Mike for the comments, I saw your video for these settings and followed it, the only thing that didn't work is that Slicemaster keeps changing the launch name from DAX1 to Slice-A and from DAX2 to Omnirig......it shouldn't be and perhaps it is the problem. Do I need to make any changes on JTDX? do I have to duplicate the files, or something else.0
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
