GNSS vs GPSDO option on 8600
From what I have read, the GNSS provided with my FLEX8600 is only for keeping the current date and time (NTP) internal to the radio, it appears to have nothing to do with keeping the frequency that the radio is tuned to stable, not drifting etc, its still using the TCXO for that.
Is that correct or does it have any application with keeping the radio portion of the 8600 stable on frequency for receive and transmit?
Phil
NC3S
Best Answers
The GNSS receiver not only provides time it also is used to keep the frequency stable. If you have it enabled in your 8600 properly, there should be a screen showing the number of satellites it is locked on to. Plus, how much the actual frequency is being corrected in Part Per Billion. It is much more accurate than the TXCO in the radio. Getting a GPSDO can increase the frequency accuracy even better. But, is much more expensive unless you need that kind of accuracy.
That is good news, to me. The comments I read implied it was to adjust the NTP computer oscillator to properly set it for date and time to be used across various applications and have the same time stamp. For correlation purposes.
Phil, NC3S
The 8600 can indeed work as a NTP server for your network, but that is not the main scope of the internal GNSS.
As an interesting observation, I tuned in a CW station before the GNSS said Locked and I could hear the pitch of the other station change as GNSS was adjusting my oscillator.
73's
Phil, NC3S
Max (N5NHJ) - how, exactly would one go about using GNSS built into the 8600 to keep the clock on a computer accurate? This would be of particular interest to FT8 / FT4 users.
John NA0A
The GNSS will give you +/- 0.5Hz at 50Mhz. The GNSS constantly updates the TCXO from the moment it is turned on.
Phil, I doubt that is what you heard until it was the exact moment the GNSS actually locked in and it moved the TCXO.
John, If you run something like NetTime on your PC, you want to point to the IP address of the radio as one of the Time servers. You will need to keep your 8000 power on (but in at least standby) 100% of the time. NetTime will then resync the clock on your PC.
BTW, for FT8, you have a +/- 2.5 second window for FT8 and +/- 1.0 second for FT4. You don't have to be that exact.
Mike…
I just checked the GNSS (GPS Tab) on my 8600. The freq Error is -180 ppb, 32 Sats Visible, 15 Tracked…
So, at 50 MHz the error is 9 Hz.
Yours is much better than mine. Is something wrong?
-1 -
As Mike says, an external NTP client can be used to sync your PC clock.
Another option is changing the settings of the Windows, Mac IOS, Linux native NTP client to point to the Flex.
For Windows:
For Windows just google "windows change time server" and you'll get step-by-step instructions.
(Sorry for the extra messages, looks like the edit/delete message feature didn't work for me)
73, Max
Hi Geoff, You were off by 9 Hz before the GNSS corrected it. Now you are +/- .5 Hz on 6 meters.
Hi Len, How do I know that is the error after GNSS?
Thanks.
Hi Geoff, +/- .5 Hz is the spec for the GNSS in the Flex. I think that the GPSDO is better than that (for big $$$), but I don't know the specs for it.
+/- a half Hz at 50 MHz is crazy good! Back in the day, if I could get my novice HR-10 B calibrated to a KHz or so, I was happy!
OK,Thanks. I suppose that's in the user guide.
HA! My first receiver was an S38-E. I think the 15 Meter band was about 1/2" bandspread on the dial. But somehow I was able to make CW contacts. Sometimes the station I was working was actually in the passband without retuning.
OK, where is the GNSS frequency accuracy spec published?
Sorry, I can't seem to find it…
.001 ppm (GNSS) is the spec. That translates to .5 Hz at 50 MHz (i.e. worst case).
Thanks Len, I looked in the hardware and software guides but not at the radio spec sheet.
Thanks for pointing me in the right direction.
Using an on-line calculator I get this:
Oh, right, .05 Hz!
I guess I can live with that!
I asked AI about it, and this is what it came up with. Sounds reasonable to me…
Frequency Stability with GNSS on the FLEX-8600The FLEX-8600’s built-in GNSS disciplining holds its internal TCXO to within ±0.5 Hz at 50 MHz.
What This Means Across HF Bands
Because the disciplining error scales with frequency, you can expect roughly:
RF Band
Frequency (MHz)
Maximum GNSS-Disciplined Error (Hz)
40 m
7
±0.07
20 m
14
±0.14
10 m
28
±0.28
6 m
50
±0.5
Phil, NC3S
- 379 Community Topics
- 631 The Flea Market
- 122 SmartSDR+
- 193 DAX
- 39 Aurora
- 263 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
