Using N1MM DXKeeper Gateway UDP Port 12060
I am using SSDR v3.9.18 on Windows 11.
While starting the N1MM DXKeeper Gateway (https://www.dxlabsuite.com/N1MM-DXKeeper/index.htm), I get an Error: Address in use. I know this is in regard to port 12060 in use by SSDR. How can I change the port to say 12061 in SSDR and keep the functionality in N1MM?
Kent N6WT
Best Answers
If it doesn't remember the port for the focus helper then you should open a support ticket so we can get it to engineering.
The CAT port is for Cluster Spots. Sorry, I got confused over that.
Did you press enter after you typed in the value? I just tested on my 6600 and no issues. I shutdown SmartSDR and restarted it and the port is as shown below…
Only 1 PC program can open the same port at a time in Windows.
Any SSDR ports for DX spots are configured in SmartSDR CAT.
Mike,
Does SSDR use port 12060 for focus helper when N1MM is selected ?
AL, K0VM
The port is not hard coded. You can change it to any port you wish to use.
I don't have a UDP 12060 port in SSDR CAT. Is this where I am supposed to change it?? Also, I don't see an option to make a UDP Port in SSDR CAT. I only see a TCP port.
I just tried to change the UDP Port to 12061 in the Radio Setup menu. When I close and reopen the menu, the number is back to 12060.
Let me rephrase that.
When I close and restart SSDR the number is back to 12060.
Mike, Al and Mick
Thanks for the help that fixed my problem.
Kent
N6WT
I now have a problem when I start SSDR I get an error. I changed the focus helper UDP Port to 12061 from 12060 for N1MM. Also, while running N1MM the focus helper does not work when I click something in SSDR
Hi Kent, do an export of your profiles, then perform a factory reset. If that doesn't solve it, submit a help desk ticket.
I created a ticket for this.
Thanks Mike
Great minds think alike... :- )
- 362 Community Topics
- 624 The Flea Market
- 8.1K Software
- 60 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 418 SmartSDR for Mac
- 267 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 9.2K Radios and Accessories
- 28 Aurora
- 227 FLEX-8000 Signature Series
- 920 Maestro
- 905 Genius Products
- 327 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 765 Peripherals & Station Integration
- 986 Third-Party Software
