Using N1MM DXKeeper Gateway UDP Port 12060
N6WT Kent
N6WT Kent Member ✭✭
I am using SSDR v3.9.18 on Windows 11.
While starting the N1MM DXKeeper Gateway (https://www.dxlabsuite.com/N1MM-DXKeeper/index.htm), I get an Error: Address in use. I know this is in regard to port 12060 in use by SSDR. How can I change the port to say 12061 in SSDR and keep the functionality in N1MM?
Kent N6WT
Best Answers
    Answer ✓
    If it doesn't remember the port for the focus helper then you should open a support ticket so we can get it to engineering.
    The CAT port is for Cluster Spots. Sorry, I got confused over that.
  • Mick  W8BE
    Mick W8BE Member ✭✭✭
    Answer ✓
    Did you press enter after you typed in the value? I just tested on my 6600 and no issues. I shutdown SmartSDR and restarted it and the port is as shown below…
    Only 1 PC program can open the same port at a time in Windows.
    Any SSDR ports for DX spots are configured in SmartSDR CAT.
  • Al K0VM
    Al K0VM Member ✭✭✭
    Mike,
    Does SSDR use port 12060 for focus helper when N1MM is selected ?
    AL, K0VM
    The port is not hard coded. You can change it to any port you wish to use.
  • N6WT Kent
    N6WT Kent Member ✭✭
    edited July 2025
    I don't have a UDP 12060 port in SSDR CAT. Is this where I am supposed to change it?? Also, I don't see an option to make a UDP Port in SSDR CAT. I only see a TCP port.
  • N6WT Kent
    N6WT Kent Member ✭✭
    edited July 2025
    I just tried to change the UDP Port to 12061 in the Radio Setup menu. When I close and reopen the menu, the number is back to 12060.
    Let me rephrase that.
    When I close and restart SSDR the number is back to 12060.
  • N6WT Kent
    N6WT Kent Member ✭✭
    edited July 2025
    Mike, Al and Mick
    Thanks for the help that fixed my problem.
    Kent
    N6WT
  • N6WT Kent
    N6WT Kent Member ✭✭
    edited July 2025
    I now have a problem when I start SSDR I get an error. I changed the focus helper UDP Port to 12061 from 12060 for N1MM. Also, while running N1MM the focus helper does not work when I click something in SSDR
    Hi Kent, do an export of your profiles, then perform a factory reset. If that doesn't solve it, submit a help desk ticket.
    I created a ticket for this.
  • N6WT Kent
    N6WT Kent Member ✭✭
    Thanks Mike
    Great minds think alike... :- )
