8600M with GPSDO
I received my new 8600M with GPSDO about a month and a hale ago. When first received, it did not look like the GPSDO was working. Since then I believe that the unit is working, but it must warm up before operating. The power light does not stay on when I turn the radio off so GPSDO is not kept warmed up. Is this something that will be solved when 3.9 firmware comes out or do I need to file a Help Desk ticket?
    Answer ✓
    You may wish to follow up with support.
    edited May 2025
    If you leave the 12V DC Power on, the GPSDO will stay running. If it does not, please open a support ticket.
    Also, the warm up time is directly releated to the location of your GPS antenna. Where do you have it installed?
  • Bill Boedeker
    Bill Boedeker Member ✭✭
    Mike, the 12VDC has been hooked up for over a month and has not been shut down. My antenna is glued to the inside of a sliding glass door which faces southwest. I used this same antenna on my 6600M with the gpsdo and it worked fine.
  • TimW
    TimW Member ✭✭
    Try the GNSS antenna that came with the 8600 if you haven’t already. The older single band GPS antennas don’t work properly with my 8600.
  • Bill Boedeker
    Tim, I tried the new antenna and it worked the same as the old one. Flex has determined that I have a bad GPSDO and is sending a replacement radio with GPSDO.
    Thanks everyone for your help.
