Control of AGC Default Level Setting
I'm looking for a way to establish the default AGC level for a newly launched slice/panadapter. I'd observed there is some recall of previous settings for a frequency and mode last visited, and it would be great to know where those settings are stored and if there is a way to edit them outside of a live slice. The main question I have though is how can I set the default AGC level for any new slice (control is identified in the attached screenshot).
Mark
AC3EW
It is described in section 18.7 of the SmartSDR user guide and you want to read the part about Persistence.
It would be most helpful if AGC persistence would remember settings not just by band, but by band and mode. The AGC settings I use for 20m FT8, for example, are very different than the AGC settings I use for 20m CW.
Tim K9WX
I wonder if the added layering you want may be best-served with Profiles?
As an example: when I want to change from 20m CW to 20m SSB, my settings (like yours) are very different. So I don't click-change from CW to SSB, but instead I leave Profile Manager open and make my selection there. This way, NB and NR are also changed, certainly AGC-T (which often benefits from daily or even hourly tweaking, depending on circumstances), filtering, etc.
I find the Persistence to be OK when I randomly listen around, but for focussed, intentional operation - the Profiles do it for me.
HTH!
Thanks, Gord, for your suggestion.
When I change modes (or, bands and modes) it is almost always done via third party software like WSJT-X, N1MM+ or DXLab. Not by interacting with either SSDR or a Maestro. Clicking on a spot is a common example.
Yes, I could create an appropriate profile in SSDR, but wouldn't I need a lot of profiles, one for each band/mode combination? Or an appropriate memory in SliceMaster but with a similar need for many combinations? And then, of course, I would still have to tune the radio to the desired frequency if I am chasing a spot.
It seems like the cleanest solution would be for the Flex to remember the last AGC setting I used when I command a QSY to a band/mode combination.
Tim K9WX
Maybe try the memories in the free FRstack software. They are easy to set up and stay constant unlike the Flex profiles that auto save any changes, making it difficult to get back to a known point.
@John KB4DU, thanks for FRstack suggestion; I always use that utility along with SmartSDR, especially its memory labeling feature. An experiment with the Radio Memory tab (the home tab for me) shows that to see the AGC change in the control panel, the affected slice needs to be selected in the slice for viewing there (yellow line vs red line). That may provide a solution to my original quest. I generally set frequencies in Memory directly from SmartSDR and that shows up in FRstack, although a check of the SmartSDR Memory window shows no direct setting for AGC there. Do you have a method for recording the AGC setting you want for a channel from within FRstack?
Mark
AC3EW0
- 354 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 174 SmartSDR for Maestro and M models
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 376 SmartSDR API
- 9.2K Radios and Accessories
- 23 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 286 Shack Infrastructure
- 201 Networking
- 140 Contesting
- 758 Peripherals & Station Integration
- 979 Third-Party Software
