Connecting my new 6400 with my SteppIR SDA 100 controller
Carl Walthall
I just purchased a new Flex 6400 radio and I'm having trouble getting my SteppIR SDA 100 controller to track the radio. It was working with my Flex 6300, but now I'm not able to get it to work with my 6400.
Does anyone have any ideas why it doesn't work?
Thanks Carl N8CDW
Thanks Carl N8CDW
Yikes, I have a 6400M and it controls my SDA 100 controller just fine. Are you sure that the cable from the radio to the controller has a good FTDI chip in use.
I assume that the 6400 and the 6400M have the same usb data available. That is the only issue I had. The cable I bought had a bad Ftdi chip.
Sorry if this does not help you, good luck.
Andy... W3LI0 -
When I moved mine to to my 6600M it took some fiddling. I don’t remember exactly what. Let dig out the note I wrote. It wasn’t much.0
Thanks Andy and Steve
I connected a new cable and I get these logging messages
23:31:11 (RX): x<E0><80><F8><80>
23:31:11 (RX): <F8><F8><F8><80>
23:31:12 (RX): x<E0><80><F8><80>
23:31:13 (RX): x<C0><80><F8><80>
I'm not sure if the commands are correct, I have SDA 100 set to Kenwood.
Thanks Steve, Andy
The baud rate for the connection between the radio and SDA 100 was wrong.
Thank you for your reply.
Carl N8CDW0 -
I have a 6400 and run it remotely. I need to use the USB jack on the back of the radio and not the PC CAT feature. to run the SDA100
Is this possible? Most of the comments show people using the PC CAT interface but I need to have the radio send band data to the SDA 100 is this possible?
thanks
dave WB7ELY0 -
If you wish to direct connect CAT radio commands to the SDA100 (or the KPA500) using the USB/RS232 port works very well. For years, I used both for those same 2 devices.
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
