New telephone line
Good morning, a few days ago they changed my telephone line and my fixed IP (public). Following this problem Smartsdr no longer connects and I don't know what to do. At home it works but remotely it doesn't. Flex 6300 + Smartsdr 3.8.21
You may need to follow the steps in Chapter 9 of the SmartSDR manual again. Sometimes rebooting the radio and the router resolves it. As well, you do want to make sure that uPNP is turned on in the router.
If that doesn't resolve your issue, you can open a support ticket and we can work through it with you.
it sounds like the ISP swapped your modem for a combo modem/router. Can you describe your network, including model of any new equipment your Internet provider installed recently.
73 Dave
Do you also have your own router? Sounds like two routers on the network with each acting as a DHCP server.
No new equipment installed, Iliad only changed my public IP and the range of ports that I can open and use
In local it works fine but in remote it doesn't
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
