Operation
I have a 8600, PGXL,TGXL. and am buying a Stepiir Urban beam with the new optimizer controller ….I understand it needs the S12 cable. What else do I need? Is there a guide on how to connect and set this up?
Hi
Page 12 of this document
What about interlock to prevent transmission until Stepiir is ready? Or is this necessary?
Also, what if you have two stepiir's?, how do we connect two cables?
if you have two of them you daisy chain there controllers. Regarding transmission you simply have to wait. It only takes a few seconds all the while you can receive.
HTHI have a DB42 no problem
Peter
Peter
Q- What about interlock to prevent transmission until Stepiir is ready? Or is this necessary?
SteppIR says no damage if RF power is greater then 100 watts RF. SteppIR has a optional "relay board" to allow you to use the PTT wired connection from Flex PTT to SDA controller, to inhibit movement.
Q - Also, what if you have two stepiir's?, how do we connect two cables?
Set up a second CAT USB cable on the Flex, associated with the second cable FTDI id. Flex has two USB ports…..if you need more, add a USB hub.
Alan WA9WUD
I have yet to have a time when I needed instant transmit upon band change. It’s literally just a second before you can do so. It’s less than 100 watts to be safe but your SWR will be high. Really it’s a non issue. You can daisy chain the controller. I think it’s detailed on their website.
I see FRStack has a Stepiir tab, does apply to Flex?
yes
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
