Operation
WA5YOM
WA5YOM Member ✭✭
edited March 2025 in Third-Party Software
I have a 8600, PGXL,TGXL. and am buying a Stepiir Urban beam with the new optimizer controller ….I understand it needs the S12 cable. What else do I need? Is there a guide on how to connect and set this up?
  • WA5YOM
    WA5YOM Member ✭✭
    What about interlock to prevent transmission until Stepiir is ready? Or is this necessary?
  • WA5YOM
    WA5YOM Member ✭✭
    Also, what if you have two stepiir's?, how do we connect two cables?
  • W2PP
    W2PP Member ✭✭✭
    if you have two of them you daisy chain there controllers. Regarding transmission you simply have to wait. It only takes a few seconds all the while you can receive.
    HTH
    I have a DB42 no problem
    Peter
  • Alan
    Alan Member ✭✭✭✭
    Peter
    Q- What about interlock to prevent transmission until Stepiir is ready? Or is this necessary?
    SteppIR says no damage if RF power is greater then 100 watts RF. SteppIR has a optional "relay board" to allow you to use the PTT wired connection from Flex PTT to SDA controller, to inhibit movement.
    Q - Also, what if you have two stepiir's?, how do we connect two cables?
    Set up a second CAT USB cable on the Flex, associated with the second cable FTDI id. Flex has two USB ports…..if you need more, add a USB hub.
    Alan WA9WUD
  • W2PP
    W2PP Member ✭✭✭
    I have yet to have a time when I needed instant transmit upon band change. It’s literally just a second before you can do so. It’s less than 100 watts to be safe but your SWR will be high. Really it’s a non issue. You can daisy chain the controller. I think it’s detailed on their website.
  • WA5YOM
    WA5YOM Member ✭✭
    I see FRStack has a Stepiir tab, does apply to Flex?
  • Alan
    Alan Member ✭✭✭✭
    yes
