TeensyMaestro
I saw some examples of making arduino working like USB stick but it would require probably at least to wire second USB port. I wil try rather to communicate over Ethernet by adding FTP Server functionnality to the board (several libraries and examples existsts to handle that).
if I make it working I will sent the code.
73 Thomas
Sounds good Thomas, I will be interested to see what you come up with!
Hi Thomas, You got me thinking, and I just found a library and sample code to allow a Teensy SD card to be accessed from a PC. I did some experiments, and so far it is working on my spare Teensy! Tomorrow, I will trim the code down to what I need and will see if I can incorporate it into the TeensyMaestro. If it works, I will post a beta test version here in the next few days and you can let me know if it works for you.
This code does not require any wiring changes; it uses the built-in (programming) USB port.
I appreciate your ideas - the TeensyMaestro will improve because of them!
Great!
on my side I was able to compile a separate FTP Server and although "technically" works it still has some quirks and will not work with all kind of FTP client so did not even try to inject its code into TeensyMaestro.
73 Thomas0 -
Hello everybody,
I am new to the TeensyMaestro and would like to make my own pcb design. I downloaded the PCB, I think from Lasse, at Lens github page and reveived the boards yesterday. Because I would like to build a differnet kind of control box combined with a ipad etc. I kindly ask if it is possible to get the kicad schematics from some of you. I know it is not rocket since to draw the design, but it is already done and it save some time. So maybe some one would share it, would be really nice!
My design will relate later on a 3D printed housing and of course I would love to share this as well!
73 de DB3FJ
Karsten0 -
@Karsten Meissner I emailed Lasse and he sent me the full KiCAD project with schematic and symbols.
If you shoot me a DM with your email, I can forward the zip file to you
Thanks Derek, because I am a New Member I cannot send a DM!
I hope I am not doing something against the rules at my first day!
lastname(at)firstname-lastname(dot)de
Karsten0 -
Sent, let me know if it went thru
Hi Karsten, welcome to the group! The KiCad schematic is on the main GitHub page.
Once you have enough activity here, your status will change and you will get more privileges. I have no idea what goes into the algorithm, but give it a little time.
@Thomas_F4HPX I got the TeensyMaestro upgraded to allow PC access to the SD card using the same USB cable that is used for power and programming. If it continues to behave properly over the next day or two, I will post a beta version here that you can try out.
Thanks for your suggestion, it is ideas like this that make the TeensyMaestro better and better!
Well, it seems to be working pretty well, so here is V1.046 Beta 1.
Extract All and load the .hex file to your TeensyMaestro. Now, if the TM is plugged into your computer, you will see the following when you go to the File Explorer:
The files on the SD card in the Teensy are shown along with a System Volume Information folder and the mtpindex.dat file that the system puts there (leave them alone). In the example above, there are three files that I put there, all ending in .ini.
My technique for editing a file is to create a working folder on the PC for this purpose. I then drag the file to be edited to the working folder, edit the file, save it and then drag it back to the SD card. When prompted, click "Copy and Replace". If you open the file on the SD card with Notepad, it will rename it which is quite annoying. Using the drag, edit, drag back method makes it pretty easy and leaves you with a backup copy on your PC.
Once you edit and save your changes back to the SD card, you need to restart the TeensyMaestro for the changes to take effect. If you wired up the power button, that is the quickest way. If not, there are three options in the Misc Menu:
- Reload CW Messages (does not reload anything else and has a bug if you reload a second time)
- Restart TeensyMaestro
- Power TeensyMaestro Off
You can also pull the power, but this is a bit tough on the USB connectors.
If you try this, please let me know how it works for you. In the meantime, I will see if there is anything that I can do about multiple edits of CW messages without power cycling or resetting the Teensy board.
Hello Len
Sorry for delayed answer but I was busy with our French Contest this weekend
I installed it and i looks fine (means working)
just the icon did not updated but this is not an issue
73 Thomas F4HPX
Excellent! Hopefully, that will make it easier to change the options.
TeensyMaestro V1.046 is now available on GitHub:
*****************************V 1.046 * *************************** Added ability to edit SD card from a connected PC. Thanks to Thomas, F4HPX for the idea!
This should be really helpful for TeensyMaestros where the SD card is not easily accessible.
Thank you Len for this add-on
73 Thomas F4HPX
De rien (Proszę), Thomas!
Hello, thanks to Len, Lasse and Derek I now have all the information I need to start my Teensy Maestro experience. I already have received the boards I ordered with the design from Lasse. 10 boards ;), so if someone in Germany needs a board to play around, I have at least 5 to give away. Still waiting for some parts, so my first SMD experience has not yet started.
My final project goal is what I try to explain here. I want to make a main body in three attachable parts for the control unit, one ipad with SmartSDR running and an additional “cheap” pad for PA, rotor, log and so on. But I want to design and to 3D print is the housing in a way, that you can use just the main body with any PC or ipad, attach the ipad and use it as one unit and to be able to add the second pad as well. I am not sure, if I will include the display and the CW button to the main design or will leave it as an option.
It would be much easier if I could share some pictures, but I am still a low level user, so I am not allowed to do so!
Knowing that some of you already made different design approaches, do you have any suggestions or hints I have to take care of?! Maybe this way I can minimize the number of trials to get the best solution for my approach.
Thanks in advance!
73 de DB3FJ
Karsten1 -
Hello Len
After few days in South Spain, I am back on my project. I tried recompile new version but was struggling to pick the right MPT library. The "original" MTP_t4 seems to be under modification and currently did not compile (at least in my case). Some others forks dating 2 years old actually compiled nicely and working, but in less "elegant" way because they do not show the size of SD card nor remaining space.Have you used a particular one or you modified the code on your own to show it?
Thomas
Hi Thomas, This is the library that I am using. I don't think that I did any modifications to it. I found it on GitHub.
I did have problems with some of the other libraries, but this one worked right away.
Thank you! It worked.
Thomas
Glad to hear it!
Hello Len
Almost done and everything seems to be OK before further modding the code for my particular setup.
As I said this is the end of the original project so there is a picture of the original housing adopted with a single VFO - pretty tight but it will fit.so just before the final assembly
73 Thomas F4HPX1 -
Looks great Thomas! Is the code modification to make the main tuning follow the active slice?
I started experimenting with code already so identified the parts to modify but for time being just fully assembled unit. In initial project the sceeen is much bigger so the enclosure had already a bigger opening that I had to refill with 3D printed adapter for current screen, but I found place to accomodate 4 press buttons nicely just below.
For time being VFO controls only Slice A and 4 knobs on the bottom on the screen controls also Slice A.
the other four on the right are controlling Slice B.
The idea I have at the end is to reassign these on the right to other functions (which for time being required each time reassignement of the Menu knob).
Once modification done and tested I will let you know.Thomas
OK, I understand what you are doing. Reassigning those functions should be completely attainable. I look forward to hearing how you get along with your project!
Hi All
After hearing Len chatting on the HRWB podcast, I found this project. Where have you been all my (Flex) life? (just kidding).
I've skimmed the thread (17 pages is a lot to consume) and I'm strongly considering building this, but I have a couple of questions:
- My 6400 is remote and I'm predominately a Mac user. I mainly use SSDR for Mac for voice/CW (I have a Windows PC at the remote site that I use for data modes). One BIG advantage (to my mind) of the Mac version is the ability to specify the IP address of the radio, rather than using either discovery or smartlink. As my 6400 is remote, this means I can use a 'normal' VPN rather than SoftEther to reach the radio site.
Q: Does TeensyMaestro support specifying the IP address of the radio? - I use a footswitch for PTT a lot.
Q: Can I add a footswitch PTT?
0 - My 6400 is remote and I'm predominately a Mac user. I mainly use SSDR for Mac for voice/CW (I have a Windows PC at the remote site that I use for data modes). One BIG advantage (to my mind) of the Mac version is the ability to specify the IP address of the radio, rather than using either discovery or smartlink. As my 6400 is remote, this means I can use a 'normal' VPN rather than SoftEther to reach the radio site.
Hi Gareth, at the moment, the TeensyMaestro just connects using discovery. The first Flex that it finds on the network is the one that it connects to. It would be a simple change to add the ability to specify the serial number (not IP) of the radio to connect to. I have done exactly that for another project, so I know that it works. If you build one and find that you really need the ability to select your radio, let me know and I will work with you to add this feature.
Note that I have not looked into what it would take to do the connect using a specified IP address. I stayed away from that because you get a different IP if you are link-local (directly connected) as opposed to using a DHCP or static IP. Since the Flex discovery works so well, I find it to be the best solution for me.
I personally use discovery with the SoftEther VPN and it works great. I assume a different VPN would operate similarly.
The GUI client (SmartSDR, Maestro) and platform (Win, Mac) that you use should not have any bearing on the TeensyMaestro's operation. It does not communicate with the GUI client; it communicates directly with the radio using TCP/IP for commands and UDP for discovery.
I have a footswitch jack as well as a button on my TeensyMaestro for PTT. I can use it locally or remotely without making any changes to the setup.
CW can be keyed locally or remotely as well. There is a config file setting to set the default and a menu item to change the choice dynamically. To use the Ethernet keying option, you need the sidetone speaker in the TeensyMaestro as the radio will not generate a sidetone in this case.
Be sure to take a look at the User Manual, User's Guide and Bill Of Materials (BOM) documents to familiarize yourself with the TeensyMaestro before you commit to building it. It is not a beginner's project, but it is not advanced either. If you have built a kit and can follow a schematic, then you should be OK.
The documents are on the first page of GitHub and the latest firmware (V1.046 as of this post) is in the Releases section.
Best of luck, and I hope to see your project here!
Hi Gareth, I just read your QRZ page and see that you built a K2. If you can successfully build a K2, then the TeensyMaestro will easily be within your capabilities.
Thanks, Len.
Using Wireshark to look at the radio's discovery packets, I see they are sent to the LAN's broadcast address. Such packets won't traverse most layer 3 VPNs as they are restricted to the same subnet. As I understand it, SoftEther acts as a virtual Ethernet bridge, but it requires the two end's LAN segments to use addresses from the same IP V4 subnet. In my case, they are quite distinct. In any case, the remote station's router doesn't support SoftEther and the remote's PC is only switched on if I'm doing datamodes.
I use Zerotier for my inter-site VPN. This can be configured to carry layer 2 Ethernet frames, but it still requires both ends to share the same IP V4 subnet.
Thanks for the offer to work through a solution. I'm off on holiday from the weekend and won't be back home until June. I'll get the components ordered when I return and pick this up then.
OK Gareth, I look forward to seeing your progress!
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
