8600 Fan noise
Received yesterday 8600 and installed it today.
Still going through some AG/TGXL/PGXL troubleshooting and setup but would like to bring up the FAN noise issue.
It will be impossible for me to use 8600 almost 24/7 (like I used 6600) as Fan noise is loud, unpleasant and not suite to be on the desk (in my opinion of coarse).
I work from home, listening music during projects or FT8 and I do not see how I can manage it now with 8600.
I understand 8600 may need more cooling, but can Flex share FAN SPECification and advice for alternative? I can look for replacement myself if I know the spec's.
I do not want to return 8600 but need to find a solution. If I cannot find a solution quickly, I will return it.
Sergey, KN7K
«1
  • Richard
    Richard Member ✭✭✭
    Sergey, I have the 8600, moved up from the 6700 and have the 6600M as my 2nd station, and the only time I hear the 8600 Fan is when I first turn the unit on as it is powering up. If you are hearing the fan "all the time" I would believe something is wrong. Definitely, not a normal operation from my experiences. suggest you generate a Flex Help Ticket to get the right Technical Expertise.
    Richard - N4RWG
    edited January 2025
    When I add one local to me, I never noticed it. However, I guess it depends on how noisy or quiet your shack is.
    As I test, I grabbed my iPhone with a sound pressure meter just to see what my shack ambient noise is and it was about 40db with bursts to maybe 50 db if I was typing. This is with 2 very big PCs running, a FLEX-6600M and its power supply.
    If I turn on my Honeywell air filter, it gets to a constant 43db.
    (if you don't know me by now, I am a fan of empirical data)
    I also found out that the iPhone was pretty accurate for measuring noise. In a previous life, we had to measure the noise of a drone and we bought a $10,000 sound device and learned that the iPhone was really darn close (but not good enough for the customer we were dealing with).
    Sergey, if you can grab some measurements and open a support ticket, that would help to make sure it gets tracked and we can then understand the root cause. It could be a bad fan or it could be normal.
  • johnn1jm
    johnn1jm Member ✭✭✭
    Mike, curious what app that is.
  • Phil_EBV
    Phil_EBV Member ✭✭
    HI All, I am also experiencing an unbearable hiss that I have tried to attenuate with a trick....
    I am just printing a one-month mini-review of my 8k6 rig, I will publish it on my web pages soon
    www.qsl.net/ic8pof/iu0ebv not yet online.
    The question is : would I go back to my Yaesu FT1000mkV_Field_modified RX in a
    super_silent shack or ....
    Phil_IU0EBV
    ps: a second 8k6 with the same hiss stays at the home of a friend of mine, I am waiting for his report too
    >........cut for oil saving ....
    > Thanks,
    > Sergey, KN7K
    edited January 2025
    @Phil_EBV Before you publish your review, please give FlexRadio the chance to resolve the issue. It would also be good if you describe more of what you are doing.
    I have also opened a support ticket for this.
    • Frequency?
    • Headphones?
    • PC Audio or Radio Audio?
    • RX EQ settings?
    • Mode?
    • AGC-T settings?
    A bit more detail would be greatly appreciated.
  • Mike VE3CKO
    Mike VE3CKO Member ✭✭✭
    I honestly don't know what all the fuss is about, I do not have any excessive fan noise from the 8600 at all. I have to put my ear within a foot of the radio to hear the fan. Same with 6700. I do have a hearing issue so I downloaded a decibel meter app on my Samsung phone with these results (average), using the phone mic at the bottom pointing to the direction of the radio :
    • 34db - 1' from front of 8600
    • 27db - 4' from front of 8600
    • 27db - elsewhere in the shack five to 5 to 15' from radio
    • 26 db - outside my shack door
  • Sergey KN7K
    Sergey KN7K Member ✭✭✭
    edited January 2025
    Wow -
    "34db - 1' from front of 8600" - I have it at 52db
    thanks guys… I passed this on to engineering.
  • Phil_EBV
    Phil_EBV Member ✭✭
    HI Sergey and All.
    I have measured with a DBMeter APP on the phone abt 33db in the quiet room, Flex OFF , and about 41-42 db with the Flex ON
    after 10 minutes warming and only in RX; the distance of the phone from the RIG about 50cm.
    I know that these values are low, but always audible even with the RIG in stby and baseband noise at low level.
    The speed of the fans stay at minimum only few seconds then go to what I suppose be the middle run, and goes to
    maximum (suppose so) when running some QSOs at 100W.
    The SPE 1k5 in stby (with 4 fans) is barely audible.
    But I have discovered the GOST in the bottle\chassis : with another APP called SPECTROID which shows the spectrum from
    0 to 10000Hz in realtime, there is a peak at about 280Hz always running as the Flex is ON;
    I have a short video but dont know how to attach it here, I will put on one of my web pages and paste the link here as I do it.
    This continous whistle makes me very nervous. What to do is to be studied.
    The room temperature is abt 19° Celsius.
    Phil IU0EBV
    ex IC8POF
    > Wow -
    Phil, please open a support ticket and add the video to the support ticket.
  • Phil_EBV
    Phil_EBV Member ✭✭
    HI Mike, of course I will do that... and ok that I have plenty of free time now, but I would spend more time being active on the bands than cutting\pasting videos HI as running after a possibly defective fan.
    Anyway I am glad that all the rest works fine, it still lacks some features but it is only software no hardware to solder\tune etc....
    I keep cross_fingers with both hands HI HA HO
    Phil
  • SIINC
    SIINC Member ✭✭
    I have my 8400M not even a week now and I can tell you that the fan noise is hard to live with no matter what you guys are measuring. I was shocked when I first turned it on. I never owned a piece of equipment with his much fan noise. I was about to create a support ticket for this issue and then came across this post. I guess not much can be done at the moment, but I hope it can be addressed.
    Al
  • Trucker
    Trucker Member ✭✭✭✭
    Flex Radio is aware of the problem and has a fix for it. You really should go ahead and open a Help Desk ticket to get it resolved. The longer you wait the more you will be annoyed by it.
    We are aware of the fan noise and it is an issue with some (not all) fans. If you have a loud fan, open a support ticket and we will move forward from there.
  • Sergey KN7K
    SIINC, I originated that post for a loud fan issue and open ticket with Flex. Fan noise from my 8600 was not sustainable.
    I was told by Flex to open radio and check if there any cables touching the FAN. It was not the case. However, I turned radio ON without cover and after initial Start UP Fan speed up and lowering speed to a "normal", the noise was still very noticeable. I pushed slightly FAN back and force and it did not change the noise, but, when I pushed it a little bit side to side, noise was GONE!
    Now, you have to distinguish if you have a vibration noise or normal fan noise that you do not like or think it is too high.
    In my case, I installed 3 pieces of foam - 2 on each side of the Fan and 1 between the panel where is Fan sitting and the the front panel of the radio. I sent video demonstration to Flex and I was told they are working on the fix (I do not know what and when the fix will be). Noise on my radio was related to a Fan vibration and 4 rubber studs did not do a job to prevent it. Now my 8600 at the same noise level as my old 6600 that it is acceptable.
    Sergey, KN7K
    We do know the root cause of the problem and it turned out to be something apart from the obvious. Sergey, when you can and it doesn't impact your contest schedule, send it back to use for the permanent fix.
  • DM2DZM
    DM2DZM Member ✭✭
    Hi, I have a 1 day 8400M and was very happy when it arrived. Now I am very sad because of the high noise. I used to have a 6400M and it was very good! What can I do now? It may be difficult to send it to the USA.
    We have a support center in Germany. Please open a support ticket.
  • DM2DZM
    DM2DZM Member ✭✭
    I have already done that, but I bought it from a dealer in DL 3 days ago and if you know about such problems, you can't sell these devices. The return shipment to the dealer also costs me another 100€, which is probably not much fun. My previous FLEX 6400M was also supposed to be unrepairable, still had 6 months warranty, didn't get an exchange and only trouble with it and new costs, then it was suddenly repaired and sold new but not returned to me. Now I had waited a good 8 months for the 8400M and am supposed to have a lot of trouble with it again.
    @DM2DZM
    We are sorry that you had to go through all that. Make sure you mention that in the support ticket. I am not at liberty to provide any guidance at this time.
  • DM2DZM
    DM2DZM Member ✭✭
    ok, tnx
  • DM2DZM
    DM2DZM Member ✭✭
    Yes, the 6400M is now back from the rebuild by DC6UW. It's gone down from 60db to 45-50db but it's still very loud when you're working with speakers and it's on the table, unfortunately. Does it make sense to install another fan from "Nocuta" or similar and which one should it be? Does anyone have a suggestion?
    tnx 73 de Peter DM2DZM
  • DM2DZM
    DM2DZM Member ✭✭
  • Trucker
    Trucker Member ✭✭✭✭
    Not very encouraging. I had hoped they solved the noise problem. If the 8600M I ordered shows up and is that loud, it will be returned for a refund. My 6600M with a new fan I bought from Flex Radio is quiet and runs cool. I would have thought that the new radios could be designed to be just as quiet using a better fan.
  • Gord-VA7GP
    Gord-VA7GP Member ✭✭✭
    My Collins 30S-1 tube-amplifier from the early-60s is retrofitted with the loud Dayton 3600rpm blower for better cooling… and I get 48dBA from that when I'm at the radio-desk. Not what I'd called "quiet", like the Dell small-form factor computers at 28dBA that I use…
  • DM2DZM
    DM2DZM Member ✭✭
    @James ok sri
    My previous 6400M was also very quiet but unfortunately a total loss under warranty
    However, if I install a new fan myself, the warranty will probably no longer apply
    73 de Peter DM2DZM
  • DM2DZM
    DM2DZM Member ✭✭
    Could some one tell me the air flow rate so that I can look for another one if necessary?
    I have not found the data from the built-in RoHS
    tnx 73 Peter DM2DZM
  • DM2DZM
    DM2DZM Member ✭✭
    Hello an new Test FLEX 8400M
    I measured a simple PC fan for comparison, also 14x14x2.5 cm at 1400 rpm
    73 der Peter
  • DM2DZM
    DM2DZM Member ✭✭
    an here is is a test from my Friend HB9BMD with FLEX6400M
    is vy nice hi
  • DM2DZM
    DM2DZM Member ✭✭
    I have now done a test in FT8 with 30W power, the fan starts up to 12V after about 10 minutes and appears to be at full speed. The noise level is then at about 80-90dB unfortunately. I have also put whole thin rubber washers under the bracket but that does not help much, whereby the fan now no longer touches the metal
    73 de Peter
