SO2R Contest recording in Dxlog
ik2egl
in Contesting
Morning
Running so2r and dxlog software I need to record audio from both receiver, A and B slice, both together.
Recoding can be done using Dax but it works only for one slice, (ie Dax 1, slice A) and I do not know how mix the two slice together
Any idea?
Don IK2EGL, AD2DC
I would use VB-Audio Banana (yes, that is the name)
And, assign Slice A to DAX 1 and Slice B to DAX 2.
You can then mix them in the virtual mixer and record it to the built in recorder. It works very well.
It takes some time to set up, but well worth the effort.
Tnx, will try
Morning Mike
could you give me some more details on your BANANA configuration ?
It would help me ,
thanks
Don
Hi Mike,
Recording works fine, thank you.
Any idea how to record the sent CW tone in the same time?
Stefan
va3ar0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 832 Peripherals & Station Integration
- 145 Amateur Radio Interests
