can the remote power on/off work on the AGXL
James Kennedy-WU5E
Member ✭✭✭
I moved my AGXL to water proof box outside, so I want to use the remote power on switch to turn off the AGXL in case of lighting and don't have to get outside in the rain to plug it back on.
Not at this time. 4O3A may have a plan for the future on this as they write all the software.
If you are not using all the ports, you could switch to a non-used port and that will ground the rest of them.
Other options are to use an IOT switch (internet of things) that you can find on Amazon to turn the AC power off. You can usually buy 3 of them for about $30 US.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 832 Peripherals & Station Integration
- 145 Amateur Radio Interests
