Settings SmartSDR CAT disappear
HB9DDS
Hello to all
Suddenly the settings in SmartSDR CAT disappear and I have to redefine them.
When I do this, everything works perfectly, of course.
The only problem is that when I create the COM ports, the COM numbers are recreated each time and are not the same as the last time. This can be a problem with existing ones.
It can also happen that SmartSDR CAT does not start, even manually
Does anyone know what to do?
WIN 10
Flex 6400
SmartSDR 3.8.20
SmartSDR CAT 3.8.20
SmartSDR DAX 3.8.20
Daniel
HB9DDS
WIN 10
Flex 6400
SmartSDR 3.8.20
SmartSDR CAT 3.8.20
SmartSDR DAX 3.8.20
Daniel
HB9DDS
Hi Daniel
Please open a support ticket.
How to do?0
Hi Daniel… on the header of this forum (when you first check in — the 'Home' page — there's a set of text describing the versions, etc. and near the bottom there's a link to 'Create a Help Desk ticket'.
Just click on that link and it will take you to the appropriate form.
Problem solved.
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 269 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
