Settings SmartSDR CAT disappear
HB9DDS
HB9DDS Member ✭✭
edited December 2024 in SmartSDR CAT
Hello to all
Suddenly the settings in SmartSDR CAT disappear and I have to redefine them.
When I do this, everything works perfectly, of course.
The only problem is that when I create the COM ports, the COM numbers are recreated each time and are not the same as the last time. This can be a problem with existing ones.
It can also happen that SmartSDR CAT does not start, even manually
Does anyone know what to do?
WIN 10
Flex 6400
SmartSDR 3.8.20
SmartSDR CAT 3.8.20
SmartSDR DAX 3.8.20
Daniel
HB9DDS
    Hi Daniel
    Please open a support ticket.
  • HB9DDS
    HB9DDS Member ✭✭
    How to do?
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi Daniel… on the header of this forum (when you first check in — the 'Home' page — there's a set of text describing the versions, etc. and near the bottom there's a link to 'Create a Help Desk ticket'.
    Just click on that link and it will take you to the appropriate form.
  • HB9DDS
    HB9DDS Member ✭✭
    Problem solved.
