unable to connect remotly to smartlink
Hi, I have smart link currently running with automatic network settings. Test function gives a green light.
when I try to remotely connect it fails with the message "registered: need to be connected locally to determine." Also the confirmed: no is shown.
Any help would be greatly appreciated, Thank you, Stuart
hi, solved the problem... please disregard
What was the fix?
I used : https://manuals.roskosch.de/smartlink-setup-guide/
to unregister and register again but kept all my port settings the same ie automatic pnp and it just worked !
One last thing , not sure if it has any bearing but yesterday your complete website was down possibly just on some servers. I had connection to it but my partner couldn’t reach your site at all
I have the same problem. new 6400 Everything is good at the hose, pauto port forwarding, green light but now for the first time, I am trying remote use and Iopen smart sdr and it immed opens three dialig boxes with my name call and radio showing available, I hit connect and it waits and then says unable to connect. tried mult times, reboot. please help. heres the data box
Serial: 1119-9534-6400-6074, Max Licensed Version: v3, Radio ID: 00-1C-2D-05-0F-82, Radio IP: 68.231.31.90, Radio Internet: NOT Available, Radio Firmware: v3.8.20.34503
thanks
dave WB7ELY
Can you show your router port forwarding?
Interestingly enough, it shows your radio is not on the LAN but it has an outside internet address. That makes it fully exposed to the Internet.
How do you have it cabled?
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
