No RX Audio On PC
I own a Flex 6400M with SmartSDR v3.7.4 firmware. Whenever I launch the SmartSDR application on my PC, there is no RX audio on either the PC or the radio. This issue seems to have started after upgrading to v3.7.4. At present, to resolve the issue, I have to close and then reopen my RX Slice. I wonder if anyone else has encountered this problem or knows of a solution.
Can you post a screenshot of SmartSDR?
Also, probably not related, you should upgrade to 3.8.20 to get all of the bug fixes and even some new functionality (squelch control).
OK, I just upgraded to 3.8.20 and still have the same problem. Everything looks normal to me, but there is no sound until I close and reopen the slice. I've included a screenshot below.
That looks ok, but check the slider in the VFO flag and make sure that isn't set to Zero.
Next, you want make sure you PC isn't muted and your speakers are your default sound device.
Your audio is turned all the way down. Turn it up and you should be OK. I also see that you have your audio panned all the way left. That is OK if that is what you want, otherwise, you may want to center it.
I see that you have PC Audio selected (upper right hand of SmartSDR). This will route the audio through your computer speakers. If you want to use the powered speakers plugged into the back of your radio, un-select PC Audio.
Thanks, guys. I just caught that when you brought it up. I can recreate it by exiting the application and restarting it. What is odd is that if I close the slice and reopen it, the volume controls are good. I would think the default volumes should work when I start SmartSDR.
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
