I have a Flex-6600 red blinking light on power switch
I have tried a lot of the methods on the community to disconnect the power to disconnect the lan cable to wait to the internal power dissipate have left it off for a whole day or two disconnected from everything tried to boot it back up, but no luck and any suggestions
    What is the pattern of the red blinking power button?
  • 160thSOG
    160thSOG Member ✭✭
    Three blinks boot failure
  • 160thSOG
    160thSOG Member ✭✭
    start the radio normally green light flashing then after a few minutes three sequence of red light starts, by the post I have read here is a boot failure, I wonder if flex would come out with a radio with a flash card recovery for boot up recovery?
    I would do an export of your profiles, then do a factory reset. If that does not help, then you should submit a help desk ticket.
  • 160thSOG
    160thSOG Member ✭✭
    ok thanks, I’ll try that
  • 160thSOG
    160thSOG Member ✭✭
    I have submitted a ticket i’ll come back on here and let you know what the recommendations are. Thank you 73.
  • denvermorton
    denvermorton Member, Unconfirmed
    Same issue here, also submitted a ticket
  • 160thSOG
    160thSOG Member ✭✭
    Tim sent me a SD card him and I think it’s a corrupted or boot failure
