I have a Flex-6600 red blinking light on power switch
160thSOG
I have tried a lot of the methods on the community to disconnect the power to disconnect the lan cable to wait to the internal power dissipate have left it off for a whole day or two disconnected from everything tried to boot it back up, but no luck and any suggestions
What is the pattern of the red blinking power button?
Three blinks boot failure0
start the radio normally green light flashing then after a few minutes three sequence of red light starts, by the post I have read here is a boot failure, I wonder if flex would come out with a radio with a flash card recovery for boot up recovery?
I would do an export of your profiles, then do a factory reset. If that does not help, then you should submit a help desk ticket.
ok thanks, I’ll try that
I have submitted a ticket i’ll come back on here and let you know what the recommendations are. Thank you 73.
Same issue here, also submitted a ticket0
Tim sent me a SD card him and I think it’s a corrupted or boot failure
- 688 The Flea Market
- 105 Aurora
