Radio Panel Cut Off
The radio panel is cut off on the right side. This started (coincidentally?) with the upgrade to 3.8.20. It looks like this:
Anyone else?
I think they call it a Scale setting. 200% might cause that to happen.
Let us know what you find out.
Hi Geoff, I am running 3.8.20 and have not seen this. What happens if you pop the control panel out and then back in?
If that doesn't help, it could be that there is a missing font set, in which case, I would submit a help desk ticket.
EDIT: Sorry Geoff, I accidentally typed your name as Greg…
Hi Len,
No joy…I tried that but it looks the same.
Hi Geoff, I would export your profiles, then do a factory reset and see if that solves it. If not, you should submit a help desk ticket.
Hi Len,
I'll try that later today. I noticed that when the radio panel is not docked it looks correct. It is only when I dock it that the problem shows up.
Here's what I found.
If I maximize SSDR everything looks normal. But, when I restore down the radio panel is cut off on the right side. Then if I slowly increase the width there is a point where the panel looks normal.
So, the radio panel is not scaling correctly.
Looks like a bug…of course, unless, I'm doing something wrong.
What is your Windows Display Zoom set to?
I just connected remotely to the PC running SSDR and the zoom was at 200%. Not sure how that happened. I don't recall ever changing it…
I'll check again when I'm back home later today.
Thanks for the tip.
Resetting the zoom to 100% solved the problem.
I'm still not sure how it got set to 200% …
2
- 634 The Flea Market
- 133 SmartSDR+
- 198 DAX
- 42 Aurora
- 956 Maestro
- 298 Shack Infrastructure
- 210 Networking
