Radio Panel Cut Off
The radio panel is cut off on the right side. This started (coincidentally?) with the upgrade to 3.8.20. It looks like this:
Anyone else?
    Answer ✓
    I think they call it a Scale setting. 200% might cause that to happen.
    Let us know what you find out.
    edited November 2024
    Hi Geoff, I am running 3.8.20 and have not seen this. What happens if you pop the control panel out and then back in?
    If that doesn't help, it could be that there is a missing font set, in which case, I would submit a help desk ticket.
    EDIT: Sorry Geoff, I accidentally typed your name as Greg…
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Hi Len,
    No joy…I tried that but it looks the same.
    Hi Geoff, I would export your profiles, then do a factory reset and see if that solves it. If not, you should submit a help desk ticket.
  • Geoff AB6BT
    Hi Len,
    I'll try that later today. I noticed that when the radio panel is not docked it looks correct. It is only when I dock it that the problem shows up.
  • Geoff AB6BT
    Here's what I found.
    If I maximize SSDR everything looks normal. But, when I restore down the radio panel is cut off on the right side. Then if I slowly increase the width there is a point where the panel looks normal.
    So, the radio panel is not scaling correctly.
    Looks like a bug…of course, unless, I'm doing something wrong.
    What is your Windows Display Zoom set to?
  • Geoff AB6BT
    I just connected remotely to the PC running SSDR and the zoom was at 200%. Not sure how that happened. I don't recall ever changing it…
    I'll check again when I'm back home later today.
    Thanks for the tip.
  • Geoff AB6BT
    Resetting the zoom to 100% solved the problem.
    I'm still not sure how it got set to 200% …
