Fans come on regularly
Any ideas will be appreciated.
73's
Jack
VK2NTK
SV5TDE
The fans are used to cool many things, including the FPGA and other Processors. If they start to do work, they may require cooling even in RX. This can also happen if the interior of the radio has not been vacuumed or cleaned out at all. You may want to open it up and have a look.
The 28C value you see is for the TX PA, not the other devices in the radio.
SmartLink would not have an impact at all for extra cooling. That is just an additional user connection.
If it really seems excessive, it is possible the fan might just be more noisy that it was and that is possibly what you are hearing.
Hi Jack… my gut tells me (if your temp readings are correct) that there may be a problem wtih the sensor or the fans themselves. I would suggest opening a Help Desk Ticket and let them help you through diagnosis.
Thank you Don and Mike,
This was an exchange radio as my original that was under warranty had a fault and I was replaced with a near new unit. I would not expect for the 6400 to have a build up of dust, however I will open the unit and just check. Once I do this I will open a help deak ticket if need be. Again thank you gents for your time.
Regards,
73's
Jack0
- 359 Community Topics
- 620 The Flea Market
- 8K Software
- 25 SmartSDR+
- 6.3K SmartSDR for Windows
- 415 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 927 Maestro
- 901 Genius Products
- 325 Tuner Genius XL
- 117 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 981 Third-Party Software
