SO2R 2 slices monitored separately
k3qh
k3qh Member ✭✭
edited October 2024 in Contesting
Hi I have a 6700 running FDX with N1MM. Is there any way to run on one band and have a second person S+P on the second band using Two computers with another copy of Smart SDR? Possibly one in the same local network using remote software? I have recently been running
  • k3qh
    k3qh Member ✭✭
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    if the radio has version 3 of smartSDR, its pretty easy. Just connect both computers.
    On a 6700 you can run SO2R on one PC with N1MM and then on a 2nd PC install N1MM + CAT and SSDR and have the 2nd operator operate like normal. Now, you can share the transmitter. This is called MultiFlex and it is part of V3 of SmartSDR.
  • k3qh
    k3qh Member ✭✭
    John, Mike, thanks so much. I am I downloading to the second computer now. I will let you know soon If I run into difficulties.
    thanks so much! 🙏
  • k3qh
    k3qh Member ✭✭
    Ok that is just too awesome!!! Got it! thank you again.
    Stuart
