SO2R 2 slices monitored separately
Hi I have a 6700 running FDX with N1MM. Is there any way to run on one band and have a second person S+P on the second band using Two computers with another copy of Smart SDR? Possibly one in the same local network using remote software? I have recently been running
if the radio has version 3 of smartSDR, its pretty easy. Just connect both computers.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsOn a 6700 you can run SO2R on one PC with N1MM and then on a 2nd PC install N1MM + CAT and SSDR and have the 2nd operator operate like normal. Now, you can share the transmitter. This is called MultiFlex and it is part of V3 of SmartSDR.
John, Mike, thanks so much. I am I downloading to the second computer now. I will let you know soon If I run into difficulties.
thanks so much! 🙏
Ok that is just too awesome!!! Got it! thank you again.
Stuart
- 692 The Flea Market
