SO2R 2 slices monitored separately
Hi I have a 6700 running FDX with N1MM. Is there any way to run on one band and have a second person S+P on the second band using Two computers with another copy of Smart SDR? Possibly one in the same local network using remote software? I have recently been running
if the radio has version 3 of smartSDR, its pretty easy. Just connect both computers.
On a 6700 you can run SO2R on one PC with N1MM and then on a 2nd PC install N1MM + CAT and SSDR and have the 2nd operator operate like normal. Now, you can share the transmitter. This is called MultiFlex and it is part of V3 of SmartSDR.
John, Mike, thanks so much. I am I downloading to the second computer now. I will let you know soon If I run into difficulties.
thanks so much! 🙏
Ok that is just too awesome!!! Got it! thank you again.
Stuart
- 364 Community Topics
- 625 The Flea Market
- 8.1K Software
- 71 SmartSDR+
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 254 SmartSDR CAT
- 189 DAX
- 379 SmartSDR API
- 31 Aurora
- 235 FLEX-8000 Signature Series
- 934 Maestro
- 54 FlexControl
- 913 Genius Products
- 331 Tuner Genius XL
- 122 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 448 Remote Operation (SmartLink)
- 772 Peripherals & Station Integration
- 989 Third-Party Software
