TGXL problem
I had a problem with the TGXL cycling unexpectedly. This was solved by increasing the DX voltage a bit to about 15 v. The last couple of days Ive been getting unexpected high swr readings on resonant antennas. When I put the tuner in standby the problem disappears. I've noticed that the tuner seems to act as an "attenuator" too when in bypass instead of standby.
The question is has anyone else seen this type of behavior with their TGXL? I am using a 6600, PGXL and AG along with the tuner. I will be opening a ticket (I suspect the TGXL will have to vacation in TX for a while) but thought I would post this to see if there was any insight as to what went kablooey.
Mike, I too was having issues with the TGXL cycling randomly. I thought it was a supply voltage problem and started using a separate +18v supply for the TGXL. This seemed to work but now I am again experiencing the tuner resetting. I have been experimenting with different routers and switches but just when I think I have solved the problem the tuner resets, drops the antenna load, and my amplifier (Alpha 89) goes into berserk mode and, thankfully, auto-shuts down. My gut feeling is that something occurs that causes an exception fault and the radio resets. Investigating if it is RF related. Frustrating …
W7NGA
In both cases, please open a support ticket. I would also recommend that you test on a Dummy load and see if you can recreate the problem.
Quite often resets are network dropouts are related to RF getting into the Switch. You might want to consider adding Mix 43 chokes to the DC power cable on the network switch.
You may also find these help.
The drop problem was cured with increased voltage. The current problem is the tuner not staying tuned and acting as an attenuator. A ticket has been opened on it already. Thanks
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
