Shutdown Flexradio
Hello. Can I shutdown Flexradio 6400 suddenly, simply cutting power?
Would it be possible to damage it?
Thanks.
Yes, you can, but it is recommended to use the REM ON connector to cleanly shut it down.
Leaving it in that state is no different to turning off a PC or a Television.
Mike, I don't believe he is taking about just powering off the radio from the power button or the rear connector.
Carsco ,
Suddenly turning off DC power ( not talking about the power button on the radio) can cause unpredictable problems as the radio saves different settings from your current session before it actually turns off the radio. You can turn off the radio from the power button or the connector on the rear of the radio ( remote switch) then wait a minute or so for the radio to actually save settings, then remove DC power without risking corruption of the SD card.
Thanks.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
